Air fryer caught fire
zueinder
Paper towel sia.
Edit: technically if you clean it up is ok. The heating element is just a coil.
tank_t
Clean all the chao tar marks and stain away can use.
unless the electrical cable melt. Or tio burnt. Dont use. Inspect properly..
mata_hippo
the paper towel u referring to those wider than toilet paper but thicker type?
this type where can put in air fryer or oven?
haiyata
TS, y put paper towel inside airfryer?
is there any reason for this?
yoongf
Find the heating coil. Shd be just abv the drawer box.
Clean as much as possible .
Turn on again to burn off any residue.
If nothing melted.. so be as good as nothing happen.
hardindex
Your fryer set what temperature?!?! You charred your food on purpose?
The ignition temperature of paper is 451 degrees Fahrenheit, or 233 degrees Celsius.
