Air purifier? - Part 2
kandinsky
Both listings are for the same exact model. Get whichever is cheaper since both also have 1 yr warranty. This was my first AP, still have two units that I'm using. Should be coming to two years already, no issue to date.
Original replacement filters cost $40+
xinping
oops i think i never look at the model properly. i think i might go for that. cost of the AP and filter are both decent.
by the way, where do you usually get the filter from?
kandinsky
Can get the filter from Sharp Service Centre (438B Alexandra Road) or Qoo10 (some local sellers have).
For me I'm currently using brandless hepa filters from taobao recommend in this thread, gotta scroll back and read. They are a generic size, don't fit exactly, so gotta DIY abit to fit. Think okay for general daily use as I'm using these in the rooms that are not bedrooms. Study/living room.
xinping
okie thank you for your replies. will buy one later :D
crunsik
anyone using Air Purifier NAP866? having sinus now and then and wondering if its coverage can cover a hdb living room size/
kandinsky
Based on the specs, yes, looks like the coverage should be sufficient. Just note the fan speed for the required coverage.
Asakura
wow nice picture example :s13:
i think many of the recent posters need this badly.
amazingone
Xiaomi's co-company, MIJIA, has just unveiled their flagship air purifier, the MIJIA Air Purifier Pro!
The MIJIA Air Purifier Pro will be retailing at RMB 1499, starting from 11 November onwards. It will be available at Xiaomi Tmall flagship store, mi.com/index.html and JD.com ~
Sent from Sumire using GAGT
Lucky177
Wow! Nice leh. 😍
This one looks tempting. Perhaps next future target? 😂😂
The Mi app is so useful and convenient for my family that has lured me to switch all to Gen1 & Gen2.
WussRedXLi
Same old negative despite being 3rd incarnation. No low, medium, high, turbo buttons on the app, which is as easy as ABC to implement since it's app implementation.
Probably no such control on the machine too (coz it only has 1 physical button). :mad:
Lucky177
Low medium and high button mode, as well as jet mode.
(Screenshot of my mobile app for Gen1)
But for Gen2, only one Favourite mode. Need slide to adjust speed accordingly. A bit the "mafun". Additional one step.
(Screenshot of my mobile app for Gen2)
Hopefully the new "pro" one will sort of keep Gen1 "buttons" on the app. Just personal preference.
WussRedXLi
Laser particle counter now
http://www.techweb.com.cn/ihomeappliances/2016-11-03/2426254.shtml
小米空气净化器Pro开箱图赏:OLED显示屏酷炫!
2016.11.03 16:53:48
小米空气净化器Pro开箱图赏:OLED显示屏酷炫!今天,小米为“双11”推出的四款产品已经悉数亮相,分别是小米IH电饭煲、小米空气净化器Pro、小米空气检测仪以及小米积木机器人。
我们快科技已经拿到了前两部产品,继小米IH电饭煲之后,下面为大家送上小米空气净化器Pro的图赏。
从Pro的命名也能看出,这款新的空气净化器是上一代的进阶版。其采用了全新设计的气流路径与增压系统,高达500m/h的颗粒物CADR值,净化性能提升61%。可适用于最大60㎡室内面积,超越前代小米空气净化器2的37㎡使用面积。
小米空气净化器Pro还配备了全新OLED显示屏幕,精确显示实时空气质量和工作状态。屏幕亮度自动调节,白天看得清、夜间不干扰。
它还采用高精度激光传感器,能精确地将低至0.3μm粒径的颗粒物分辨出来,快速实时响应,瞬时反馈数据,精准反映空气质量。
该空气净化器售价1499元,将于11月11日零点开售。
ralliart12
Weirdly noisy fan from particle counter?
May I know if anybody else uses this specific model of particle counter?:
I got one recently & observed that its fan is significantly noiser than my older, simpler model. Do check out the video below (with sound turned on max; you will hear a humming when I picked up the newer model & hear nothing from the exposed fan of my older model):
Or is mine spoilt?
ralliart12
me. something similar. but never noticed any noise before
May I ask a favour from you?
Can you help me power yours (the one with the "more"-enclosed body) on, & listen closely to the side where the fan is (you should be able to see the square black fan through the grills)...
Can let me know if you hear any buzzing/humming/any noise at all?
If yours have no noise even at such close proximity, means I've got a dud set on my hands...
