Air purifier? - Part 2
WussRedXLi
Ohmyshop selling filter for 65, qexpress inclusive.
I think you can just diy cut the 30x30x2.5 or 40x30x2.5 TB HEPA for other times. Rmb 25 and rmb 35.
WussRedXLi
For those who want a 300m3/h class machine that's energy saving and presumably quiet and have multiple speed control, i think you can try the Lotte LE-901. DHL safe too. Filter sgd 65, stock up or not up to you. Can go for cheaper option like the rmb25 or 40 commoner TB options (no need to alww, just place order)...up to you. They will work.
Dont only place your hopes on carousell/gumtree esp the BNIB cheap one which come like a few times a year and v limited sets. I think a lot of people are aiming also for the next 6 months.
Besides, you wanna customise filter, also need 30 dollars odd per piece at least.
Can spend that few more tens of dollars to get a brand new one. Heck most second hand ones arent cheap also.
LE-901 also can adjust the sensor sensitivity, so that the Auto mode can be tuned.
Just some thoughts.
Class 2 for energy/airflow efficiency. Same as LG LA-Q379SB/PS-R459 and Samsung AX40
orangeman
Jiak Lat the damage for the mFresh.i bought the xiaomi AP durin 1111, praying hard now
LFC25
Maybe LFC25 can describe abt the LE-901
Yes, this AP is quiet. It has 4 speed modes: Night, 2, 3 and Turbo.
I use speed 3 even when I sleep. Surprisingly my watt meter reads only 12w at this speed. Very economical.
I find the odour/dust sensor well designed. It is mounted and exposed on the back panel therefore it detects dust or odour quicker, unlike AX40 which has a cover before the sensor.
The sensor also comes with three sensitivity levels i.e. Low, Med or High that you can adjust.
WussRedXLi
If use 顺丰 (with fragile sign usually) and 4PX and Speedpost, the risk is very low.
Not sure if you remember 2014's 11/11 horror stories, even in Singapore with all the other couriers leaving the thousands of packages out in the open dripping rain. Coz insufficient cover. But Speedpost is fine.
But actually, every year's 11/11 is the same. My China colleagues say so too. Standard ba.
WussRedXLi
You also bought it, WussRedXLi ?
Nope...no use for that liao. I will get another big one for any moderate El Ninos again (eg 2006). I prefer a few big ones vs several small ones.....from the experience learnt in 2015 with the meters. Eg bedroom no need AP, still can hit below 15 ug/m3 raw with external well over 300 ug/m3 raw. Need to aircon the house also....
We hit PSI 150 based on PM10 in 2006 also. Not a low level. Which is probably mid 200s ug/3 for PM2.5
NWT1978
Just some thoughts.
got nice colors light up when switching on :s12:
Any air cube users here? Did you manage to update your air cube? There seems to be any update but failed when I tried to update it. :(
Got meh? IOS or Android?
Not the app. It's the device. Maybe the firmware. When start-up, there is this message that ask me to update. But when it's shutdown and when I need to power it on for updates, the app just closed. Restarting the app doesn't allow the updates to be applied. Zzz
WussRedXLi
Wah...AX40 time sale. 284, free extra filter. Happy mall. Where to find....
