Air purifier?
derazor
Got stock what...
It restocked on Friday, and then sold. Then Saturday huge stocks came at 100AM Guardian and Watsons, some 200 boxes. Also gone. Today came and see S and M (Orchard Gateway, 100AM), then also gone.
a lot of ppl buy but I don't see ppl wear :s13:
WussRedXLi
so basically its relying on charged up air/ions to suck in dirty air towards the unit
the discharged air escapes the unit
thats how its creating airflow on its own without a fan?
Not sure what kind of concept are they trying out. If it has no airflow moved over the collector plates, it's a totally flawed design then.
Electrostatic precipitators need fans as well.
See this, 1 min 30s.
linusz
Recalled someone is considering to help buy ax40 custom filters from tb. Need 2. Can help tompang if still on? Who ah? Thanks
sky00sky
actually what is the dimension for those ordering ax40 custom filter?
i measured is 28 x 31 x 5 (but 1 cm is the carbon) so should be 4?
Asakura
i too lazy to quote the post for measurement again for 999 times lol
Asakura
cant really gauge from the video in their website also bcos i think it was done at corridor or some sort
the 1hr test. the psi reading hardly moved between 60-70.
if its a closed room. thats even worse.
and i think even if i blow a fan towards the unit wont be of much help? even if it does den i need AC+Fan+EP? lol
IIIUSION
Sorry if this has been asked before, but is there any chance that a AX40, being a 60Hz unit would cause a fire etc? Other than knowing that it will run about 20% slower...
What is the additional risk over the standard local approved 50Hz?
lalalalalala
Run slower won't cause fire what, if anything it should be run faster then catch fire :s22:
JoePilot
The fan motor is a DC motor, no issues with frequency.
WussRedXLi
Good question. Answered before last year, but too long ago...... glad you brought it up again.
It has a Nidec 310 Vdc motor and is powered by a SMPS. The SMPS "would take the hit". The Vdc motor would not know and would not care.
I have been gunning the heck of it for 1.5 years. 72 hours no issue.
Lots of smoke alarms here also, ionisation + photodetector. 2 x 3kg ABC. Fire blankets. Smoke escape hoods.
Here :
WussRedXLi
PS. Extreme right = live and neutral. Middle cable red white blue is to the motor (control wire also I guess or something). Right socket grey cable is to the touch panel controls.
