Air purifier?
Shahmatt
The VirusDoctor generates active hydrogen and oxygen ion, which forms Hydroperoxy radicals (HOO–). It reacts with virus and turns into harmless water vapor (H2O) Also the active hydrogen (H) combines with OH-radical and forms water vapor, neutralizing harmful OH-radical.
search virus doctor in thread. got post a few videos
some ionizer charge up negative/positive ions so dust particles attracts together, make it falls. so not just ozone, what if u use pure ionizer without air purifier, what happens to all the extra dust created if u dont clean the air? more dust.
Thanks. So just to understand:
1. For Haze there is no need for VirusDoctor right? So I will keep it off.
2. Ionizer maybe I will switch on if psi is very high - maybe 200+. The HEPA filter should do the job anyway correct? And also ionizer will take up more electricity.
nwh_sg
1. Yes there is no need for VirusDoctor for haze.
2. For me I will switch on ionizer when one of us (my wife or myself) is sick, eg. having flu. Else not much point. Anyway, heard (not sure) that the effective zone of the ionizer is quite small.
Asakura
level is way lower than the safe level.
or close to none
only for certain brands that are tested.
this one also mentioned many times in here by WRX
wkweksl
Interesting observation
4 pieces of DIY HEPA 300x300x25mm volumetric - 0.69kg
1 piece custom AX40 HEPA volumetric - 1.52kg
tildveryn
Samsung AX40 vs AX041.
Are they using the same filter?
so the only difference is it that AX40 comes with ioniser off by default whereas AX041 is ioniser on by default and it cannot be turned off?
WussRedXLi
Any recommendation on where to get filter for Midea? Those on taobao looks shady with their reviews. Mine is going to reach full charcoal black stage.
No experience on this though. I think can just alww and trust seller, anyway rmb 99 only. Try 1 pc
mindgamey
Just received my spare xiaomi spare filter.
This one is the high density AC filter.
Didn't know I can remove the middle AC filter.
mountain turtle
kimsim
Suspended
@idiots
Your DIY 370x234x45mm will be on the way by 2nd batch, has been placed ur ordered :D
mindgamey
at the end of the day its flowrate x filter efficiency.
flowrate is the most important if efficiency is more than 95%. an increase of 1% will make little difference for a machine that can push 300-400m3/h of clean air
