Air purifier?
laeticia
Was busy this afternoon so missed the time sale! Time sale can't use coupons right so still not so bad...
kandinsky
This is still cheaper. IIRC, the previous price drop when you bought was $66. There was a $10 off $50 coupon, after applying, it still worked out to $56 :)
laeticia
I managed to get a couple of $10 item coupons saved up so with the current promo of $58 and with coupons its $47 before q-points. Planning to order tonight after I collect the final batch of 100 daily q-points so total for me will be $38 each :)
I kept delaying so didn't order from Happymall at $66...
laeticia
Is it possible to get a zero reading on air cube? Tried placing in front of AP and the reading is the same as for the room.
Mine went a little crazy yesterday after I updated the software and suddenly registered a hazardous spike but calmed down after that lol
LFC25
what version are you using now?
mindgamey
NV zero the best is 20+
I think 4 bar can trigger alert
kandinsky
Nicely done. :s12: Which coupons are those btw? The only $10 ones now seem to be all $100 minimum spend...
laeticia
Thanks :D
I'm using a $1 item coupon and a $10 cart coupon for items above $30
The $10 coupon is from the qoo10 mobile app, for the first time after you dl the app to your phone.
