airbrush and compressor buying help!
r_apid
so i want to buy a good compressor and an airbrush for long term use. Been thinking on buying Sparmax TC-610H and airbrush Sparmax DH-103 from hobby art gallery. However they dont let walk in purchase.Since i dont live in singapore,i need help on where to buy a good compressor and airbrush that allows walk in..and also please suggest me a good compressor and airbrush which can be used for long term use :D my budget is around $300..thanks! will appreciate the replies :)
r_apid
thanks! just wondering, what do you think of Hobby mate HM5000 compressor and its airbrush Hm135?is it good?hag sell it for $298 for both which is cheaper the the sparmax.
Jhyun
Personally I would prefer the sparmax if budget isn't an issue.
Compressor wise it's much superior, can't say about the airbrush since I haven't used the sparmax one before.
