putrasocool
- Jul 22, 2013
I am assuming this is the right place to put this thread...
I move to this house ~3yrs ago... Install new aircon.... Prvsly no aircon...
Mitsubishi Starmex Inverter 2 Split
Done chemical wash once due to foul smell after a yr... Now okay alr
Done servicing 2/3 times only by company...
The rest I do on my own like cleaning the filters, the vanes and all...
Now a problem emerged...
Water leaking somewhere from the aircon...
Thought it was the PVC drain pipe... Open up and check that the coil pipes' are wet and dripping water...
The wierd thing is both my aircon having the same problem... The 2nd room even got water dripping from the plastic case covering the tubes and all...
Called the company i bought the aircon from to check if have warranty... Cz at that time assuming the coil needs to be changed... The clerk says that its because i rarely service... I have to agree with her that i rarely service due to time and laziness...
Usage of aircon:
Midday if hot
Whole night
Is the clerk saying the right thing? Should i get it serviced to fix the leaking problem? If yes, ill do it right away...
Usage of aircon:
Midday if hot
Whole night
