derrickgoh
- Jan 1, 2000
Am using mitsubishi starmex. A bit confused after hearing various things.
All along i used fan speed 3 (max is 4) & temp 26 which i find just nice. Then someone mentioned fan speed too low no good cos can cause condensation more easily. Is this true? And is speed 3 considered too slow?
Anyway so i tried turning up to speed 4 but at 26 degrees it was freezing. So i had to increase to 28 degrees. Then some other ppl said aircon not cold enough easy to have condensation!
Walau like everyone got different theory. So which is true? And which is "better"? Max fan speed (in this case 4) which TBH is quite loud & higher temp eg 27 or 28 degree? Or 2nd highest speed (3) which is less noisy & lower temp eg 25 or 26 degree?
I just want a temp which is just nice for me but not a setting which supposedly causes condensation so easily.
