Amaron Battery
pb
Amaron seems more costly than other brands like Yuasa for maintenence-free. Is it worth the extra $$?
cheers!
crazyliao
Sorry to steal the thread...has anyone tried HYUNDAI maintenance free battery?
can share if it is good and lasting?
Thxs.
devilcup
Thxs.
Hyundai Enercell is solite brand
it is oem for hyundai and kia car :)
it is ok battery i think. since i widely use in korean car :)
InsaneClownPosse
the last Hyundai batt gave up on me only 1 yr after i change it !!!!!! :s27:
now im using amaron
kakaBoBo
upsize battery and upsize alternator loh.
very worth it.
aaur4man
how much is an amaron?
mine is the version that my fren told me can see the indication whether it is still usable.
self installation shd not be a problem.
cos i encounter sometimes start engine takes abt 1.5s instead of 0.5-1
gentoro
Can call CDGE cos they dealer in Amaron. Some other garage also carried amaron, can chk with them. Btw, note ur battery model/size to get a quote.
FlameEvil
amaron i can say most of the cars here are using it including myself ;)
subaru1.6
Me Using too:)
nmnhnlm
now im using amaron
The problem with MF batt is that you don't know how long it has been on the shelf...... that batt might be sitting there for 2years before you bought it.
If possible try to find out the manufactured date before buying.
hpv500
think its abt that price...got mine ard the same at SPC...
