- Sep 16, 2018
1) I can not find any good info about whether Amazon eero TrueMesh supports any of the standard 802.11 k/v/r standards or not.
https://eero.com/en-GB/technology
2) Typically consumer mesh technology like Asus AIMesh and TP-Link Deco will be based on 802.11 k/v (sometimes also 802.11r), then adding proprietary mesh technology. 802.11s is mentioned to be used by Google's Mesh solution.
OpenWRT mesh guide, mainly using 802.11s
https://openwrt.org/docs/guide-user/network/wifi/mesh/start
OpenWRT Wi-Fi Roaming using 802.11 k/v/r
https://openwrt.org/docs/guide-user/network/wifi/roaming
3) Some experts are saying as long as the nodes support 802.11 k/v, then the roaming performance will not be bad even if mixing different nodes (all nodes in AP mode, or except the main node).
4) Then some experts like to DIY, changing the placement, transmission power and frequency band, to try to achieve seamless roaming. They do not care about 802.11 k/v/t or 802.11s.
5) To layman, I think it is better to use the same vendor's same mesh technology.
For example, TP-Link has different mesh technologies and they do not recommend users to mix different mesh technology.
https://www.tp-link.com/sg/support/faq/3749/
