Jurchen King
- Dec 16, 2007
Question for AMD Radeon GPU users:
We know AMD GPUs by default boost way high above specified maximum frequency, causing issues like driver time-out or crashes.
Last time Adrenalin software can set the exact maximum frequency to stop GPU from over-boosting above manufacturer specs. But now Adrenalin software has removed this setting and replaced it with a Mhz offset slider.
So how do you know how much offset to set in order to match manufacturer specified maximum boost frequency? For example, let's say maximum boost frequency is 3020Mhz. If left at default, confirm software will over-boost above maximum frequency. If offset too much, then performance drop below what you pay for. So how much offset should be in this example?
Thank you for your expert advice.
. After I've locked in my tuning settings, I'm shocked but happy to see my GPU consume between 145W-253W of power and temps consistently around 60+ degrees
. This is way below the 304W TDP of my card and GPU fans are silent. And I'm still hitting/exceeding the FPS maximum refresh rate of my monitor.
