I targeting xiaomi pad 7 now. Will compare with samsung tab A11+
Any xiaoxin pad that's 120 to 200 is good deal. Buy Lenovo won't go wrong
My ipad air lasted 8 years , only changed batt onceSorry I mountain turtle I never use tablet before
I want to ask can tablet use wechat or not
And how long does tablet last for a normal one ?
The battery is it ok ?or can change battery to make it last longer life ?
No software support, heard the build quality also quite questionableAny xiaoxin pad that's 120 to 200 is good deal. Buy Lenovo won't go wrong
Lenovo XiaoXin 2024 quite good, their stylus had good performance for sketches and note takingNo software support, heard the build quality also quite questionable
My 2020 Pad Pro received updates all the way till end of 2023. Still going strong.No software support, heard the build quality also quite questionable
out of curiosity, why not xiaomi pad 8?
Read HWZ Forum Rules!
Also launch price likely not as cheap as Xiaomi pad 7Singapore not launched yet.
Huh go this kind of daiji meh? My lenovo xiaoxin no such problemuntil u messed up and forget the google account that u used to log in. there is a protection that require u to login to previous google account even if you had already done a factory reset and clear cache.
Google: Lenovo Factory Reset Protection
My the one i have is no such problemsNo software support, heard the build quality also quite questionable
