Anti Theft Solution for PC?
zheng
can recommend me one?
and how does it work? i know there is GPS and do remote spy cam
but if the theft have no access to the window login mean no internet even got cam also cant capture him?
davidktw
Why do you think until so complicated ? Your cheapest and most effective method is this.
image.php
zheng
i dont think u would carry that around and lock it to your bag?
davidktw
It's not large actually, but of course, if you feel it's a hassle, then you better don't leave your eyes away from your laptop :)
You are asking for sophisticated solution which cost a lot more, but have you consider if they are effective at all ? :) All I need to do is dissemble your laptop and take out parts I'm interested in :) Do you think your security measure will still work ?
If you know you are going to some places and you are going to leave your laptop alone, then I suggest you have such a lock.
Question for you is, where are you going all the time ? Can you just leave the lock at the place you will be at, provided it's a place you will always be there.
flee0308
What if people steal your battery lol.
mistersatki_
ehh ... stolen stuff = tiak open take out the hdd
swap a new one in
and walahhhh ! its a brand new laptop !
Rock-kun
Good question, no security better than eyeballs :) BTW My MBP can't have the battery taken out easily :s13:
I'll make sure I come prepared with pentalobe screwdrivers and alcohol to break the adhesive bonds on the glue-ed down battery then. :D
