Elijahoni is right. Unless you are prepared to shell out thousands for the highest end monitors that can go really bright, the HDR label is quite pointless. Even for those that do, I’ve not seen one that has implemented fald really well, so blooming is quite obvious.I’m using ips panel now. Not sure if go to va panel will have big difference or not. Ips seems like twice the price of va.
Ok then I don’t know lah. Don’t change monitor for now. Wait another generation.Elijahoni is right. Unless you are prepared to shell out thousands for the highest end monitors that can go really bright, the HDR label is quite pointless. Even for those that do, I’ve not seen one that has implemented fald really well, so blooming is quite obvious.
IPS monitors are known for better colour accuracy and better viewing angles, but the compromise is usually speed/refresh rates. No free lunch. A good quality high refresh 1440p ips panel usually costs a pretty penny.
No lah 49” is too big. My desk don’t have the real estate.last month acer clear stocks of x35 with all your requirements, at $2.3k after platform vouchers
think new version coming with samsung 32:9 panel, best is have hdr 2000 mini-led!
https://videocardz.com/newz/acer-ei...r-features-vesa-displayhdr-2000-certification
It has adaptive sync so I supposed it works with both. I have nvidia card so cannot verify for uThis predator x34GS monitor got freesync?? Because it only mentioned g-sync in the spec.
Nice how the 3 years or 5 years warranty ?This predator x34GS monitor got freesync?? Because it only mentioned g-sync in the spec.
3 years nia.Nice how the 3 years or 5 years warranty ?
