Anyone facing problems with Maverick??
singexpat
Am using a 2010 MBP and i noticed the following problems/issues aftering updating to Maverick
1) Time Machine cannot backup.. Keep saying "Preparing for Backup" (its a external hard disk)
2) Apps opens slower (e.g. Preview when opening mail attachments)
3) "Search function" in Mail will only show a) all results thats AFTER the Maverick update, and b) selective results BEFORE the Maverick update.
However, if you scroll manually, all the results are there..
Please share what bugs or issues you encounter, and hopefully, solutions.
Cheers :)
Hobbit6003
One problem I encountered is that whenever I open my Mail app, they keep asking me for my iCloud password. I thought I had set up my keychain already...
singexpat
I do kena tht prob under mountain lion..
siao siao one.. But only for certain email accounts.. Some accounts r fine..
speedster4005
After the update, i encountered issues on:
1. Updating the iPhoto and iMovie - it says "updating" for ages that I lost my patience ;-)
2. Microsoft Word crashes when I open a document.
And since I was lazy to find a solution for each of these issues, and maybe time for a spring cleaning, I did a clean install using a USB drive.
Hobbit6003
Ok, found a solution to my problem with Mail app while searching the web:
1. Go to preference and open iCloud.
2. Uncheck Mail, and the re-check it.
3. Reopen Mail.
4. No more asking for password to my iCloud mail account.
Hope this helps others who have similar problem. :)
singexpat
Possible to share how to do clean install??
Will existing files and configurations be removed akin to factory reset? Pardon me, noob here.
Tks
speedster4005
Tks
Two options:
A. Create a USB installer (if you want to deploy to multiple machines or keep for experiment hehe): This was what I did. I followed the instructions at
http://lifehacker.com/how-to-create-an-os-x-mavericks-usb-installation-drive-1450280026?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+lifehacker%2Ffull+%28Lifehacker%29
B. Install using Recovery Partition (if you have already installed Mavericks before on that machine), this was what my colleague did a while ago:
1. Reboot, hold the Alt button after the "boing" sound in order to display the boot options.
2. Select Recovery-10.9. This will display the OS X Utility menu.
3. Select Disk Utility. Select the drive for installation and erase it using the Erase option.
4. Exit Disk Utility. You will be brought back to the OS X Utility menu.
5. Choose Reinstall OSX and follow the instructions.
That's it. And yes, all your data will be wiped out. There are options to actually back them up and restore but I have never tried them.
tjkb230
somehow startup is a bit slower
and some glitches with mac app store
Laneige
hmm so far so good BUT
i last time created the folder and tab with some colours. the whole folder will be highlighted with that colour (filename)
now, its just a pathetic colour dot next to it. no good
leinad
And I on the other hand hated the coloured filenames so much I never used it. Felt it was rather over the top, in your face, see-me-now. :s13:
/Dan
Laneige
/Dan
"anti" you. must be users like you that complaint. hahah
i find it good because one glance i know which is my most priority folders.
singexpat
Two options:
omg.. In this case, I hav to live wif e flaws first till they issue another update.
cannot risk losing my 3yrs worth of data
erwinrommel
I am really facing problems with my iPhoto after upgrade.
Tried downloading the new version, and it kept bouncing error message about cannot purchase/update, and the progress bar kept showing it's about to complete installation.
And another issue is not due to Mac, but its about Parallels 7. Can't be used in OS X Mavericks and is forced to upgrade. :s22:
But other than that, the Finder Tabs are indeed useful! And one more minor issue for those who often change wallpapers. Finally, one can right click from the list of files in Finder and change wallpaper, rather than navigate to Settings.
But my major gripe is still Mission Control. Still prefer Expose and Spaces since I am using an iMac, and the large screen is useful to expose all the running documents...
leinad
Hot corners for Expose? :) Or the F3 button on the keyboard should work too.
I use the top right corner for Expose.
/Dan
