Anyone using Motolite battery?
jameshong
Hi,
Has anyone currently using "Motolite Gold" maintenance free battery for your car? Can't really find any review in the net so hope somebody here can advice the Pro and Con.
Thanks.
tek888
Hi,
Thanks.
I used this brand twice on my previous car. It was ok, just a normal battery that last over 2 years on my ride.
tek888
Wow, can last 2 years should consider good liao lo. Are your Gold or Enduro?
should be gold. yeah, I usually replace the maintenance free batt before they turn 2.5 years as there isn't much tell tale sign before the batt fails. Unlike the old lead acid batts that will exhibit weakness before they fail.
