Anyone using outdated Android phone?
FinalTidus
Outdated as in still on Android 14 or security updates more than 6 months bo update liao. :o
Planning to buy phone soon?
Android 14 is definitely very far from being old or outdated.
Even Android 9 can run all apps comfortably well.
Maybe if Android 8 and earlier then I will consider that old and outdated.
leonaheidern
my mum has Huawei mate 10 pro wor
android 10.
she uses it for social media and Whatsapp and for her hearing aids
thankfully finance and govt apps wise i force her to Migrate to iphone 15 plus
which also suddenly become just outdated ah
Read HWZ Forum Rules!
Kiwi8
Deluxe Member
No need to buy new phone as long as the apps still work on the phone.
NightGhost
Planing too but no iphone sexpensive
those outdated many apps will not sakpork n will uninstall by it self.
Flexamoria
My old android no more Firmware, only recently security patch, but battery life no good
tian_yibang
Well , sometimes notch updating seems to be the safer option
After update, all sorts of "colourful" lines and bugs/glitches kanna tio
:s13: :s13:
SayPorkGuy
imma using pixel 3a running on lineageos equivalent of android 15.
zueinder
Not me but my p30 pro outlasted a S22 pro and is still in active use. Although is considered light usage.
PeasantBeing
If use banking apps, best to have a phone with updated software and security patches. Can buy a cheap phone with 2 year updates or so. Look at the cheap Xiaomi or Poco phones.
jinsatkilife
Anyone know how to get update android if OEM stop support?
I got spare phone android 9 and want install apps but some apps only support later versions of android
Is there way to flash updated android if u managed to find bootloader unlock
poland_ball
Got 3rd party ROMs. But need to check if your hardware is supported. If is those niche brand can forget about it
Lao_Tiko
Possible but i'm not sure if you want to go through the hassle of installing custom ROMs with later versions of Android than what is officially supported by the phone manufacturer.
And if the phone is being used for banking transactions or stuff requiring Singpass, you might want to research around a bit because they might not play nice on certain custom ROM versions
But it is a fun project for school holidays. So why not?
Some China phones with international ROMs are good candidates. Redmi, OnePlus, Pinephone etc
OutBreak
I have a Huawei Mate 10 still on Android 10. I use it as a spare phone. Most of the time it is offline.
Scp173
I always use a hp till it's really going up lorry then buy a new 1.
Same as me
Android 9 max on my phone
But now new samsung flagship good, they mostly give u up to 7 upgrade
Last time wher got so good, 2-3 time update and no more and u stuck with wadever last android ver they giv even if ur phone is good for another 5-6 yrs
