Anyone using Schneider Electric Switches
jolintay
I am looking for designer switches for my home. Seen some nice ones in Hotel but when i visit some hardware shops, i don't see them. Not sure where i can find. Came across Schneider Electric website when i do some google search for switches.
Any feedback on Schneider Electric switches?
lousylah
Both French brands but Schneider more "branded" there are dedicated hardware shops for switches in rocher area where many brands are featured.
kyteo79
go phulux u can see awhile range.
Hope you have big budget ..
durkheimian
Choo Chiang Marketing have, but not sure if they are Schneider. Could be MK ones.
jolintay
Thank you for all your suggestions. I will drop by Choo Chiang over the weekend to check it out. By the way, my friend recommended this brand Clipsal to me. She said it is an Australian brand. Anyone knows where can i find Clipsal switches?
cscs3
Schneider not bad, use before and last very long. Now changed mostly to switches bough from Taobao.
jolintay
I have got my SchneiderElectric Switches
I have finally made up my mind which switches to go for. After much consideration between Legrand, Gira and SchneiderElectric, I have decided to go for Schneider Electric Pieno. It looks elegant and the shop gave me a good price. It is a happy day.
PiPiChew
Dont mind pm me which shop you sourced your switches from and at what price? Thanks!
Sent from 富贵山庄 using GAGT
pvoliew
Schneider switches
Hi, don't mind to PM me too, I'm looking to invest on new switches by mid of next week, thanks in advance.
Paul
galliano
Like the Schneider Pieno switches also.
Saw Homepro@Paradigm, Johor selling 3G1W for RM36ea.
Worth buying?
Wondering any issues with Pieno switches.
djr81
Currently using this model.. super like it..
Anyway this model is bery bery long design i win say maybe 7 years? Before that is clipsal brand now is under schnider
:s22:
limpingsim98
schneider electric singapore the switches q nice leh good to use anot?
They make good product but I feel they are more plastic feel. Personally I preferred MK which is make in singapore vs made in china. However MK is more expensive.
LoneTraveller
Plastics is a bit soft. Never like it. MK is better.
Which part soft? Using it in my new bto. So far so good. Just find the 3 and 4 gang switches is a bit loose in terms of the individual switches. The same can be said of mk which i used for 10 years in my previous 4 room. There was a batch of bad mk switches which caused me to switch to schneider as the switch covers keeps dropping out. 😂😂😂
cscs3
I think he refer to the on off toggle portion. Mine also broken. Used about 3 years plus.
jolintay
JudyOwl, can you share with me where you bought the schneider electric switches and their price range?
