Anything issue with this build?
Ark Law
DSP: Dell S2340L 23" LED [eIPS] @ $199
this monitor is already quite good. no need to change. Its IPS 1080p display already
Anymore comments?
Can consider this less-than-a-year-old higher end Dell 2nd hand. Warranty still longer than the S2340 brand new, plus you get a better stand & anti-glare matte screen
http://forums.hardwarezone.com.sg/graphics-display-bazaar-200/wts-u2414h-monitor-5008531.html
Silverback84
IKEA still have GALANT left? Grab them while you can. And better get the 160 x 80 cm version if you have enough space in your room. I have the 120 x 60 cm one as my study desk. Still okay but placing PC will be rather crammed.
Yeah I'm getting it soon. Then get the computer built.
Mikiberry
I really don't suggest ikea fiberboard tables. The Formica used is really bad. Once u had a wet surface with coloured prints on the table That is it.
The Formica will also bloat. I suggest looking at neighborhood carpentry stores or vhive.
Silverback84
I intent to see the table 1st b4 buying.
MoneyFace =p
Even for the ones used on GALANT tabletop? I always thought they tier their material quality for different series. Isn't GALANT supposed to be their high end series?
Anyway i've seen some V.hive desks and they are similarly priced as well. So do consider.
