Aorus Engine custom fan curve setting
ystoh133
Hey all,
I've always been on gigabyte's xtreme engine for the fan curve, but recently after getting the rtx 3070, it doesn't seem to work so I had to use their newer aorus engine.
Problem i have with the fan curve now is that, the below points somehow are anchored to each other and I cant set a "gradient to it"
fb3BJID
Proximus
Hey all,
fb3BJID
tbh... aorus engine is pretty crappy (looked at all the complains in Reddits). You are better off using Afterburner.
