AORUS X3 Plus
roasted
Just found out a new released review from hexus.
Sorry couldn't post the links due to insufficient post counts. :s22:
xXshad0wXx
yea saw that while the gpu says cool and good. there are throttles in the cpu. but overall a good system to have!
xXshad0wXx
Excited to have my hands on that beast. just a few days to go..
ur gonna buy aorus x3+? price is steep roughly 3.5k abv... cpu throttles i think x7 v2 is better more of a beast that this. 860m sli beats a single 880m in sli optimised games
roasted
got mine same price as ghost pro. was opting to get ghost pro but this guy popped out by the end of the month so i just needed to be patient. XD
xXshad0wXx
same price as ghost pro? ghost pro is 2.9k! how can the aorus x3+ be 2.9k as well?
QQQ321
to me getting a laptop means light and portable if not don't bother at all.. that was the reason i bought the first gen razer blade 14... but this X3 brings portability to the next level, furthermore the new blade is heavier and thicker than the first gen.. so for me X3 hits the right notes...
GS60 has HDD bay ...
If you take out the HDD and weight will be 1.8kg also
I was wondering How come a 13.9 inch laptop weitht almost the same as 15.6" one......
xXshad0wXx
materials used. gs60 uses a magnesium alloy chassis which is very light but sturdy. aorus suses a heavier material. but the gs60 does have quite a bad screen flex ( screen feels flimsy) while aorus x3 has minimum flex. hence there is alwayss a tradeoff. gs60 bigger screen but build quality not as good. aorus smaller screen but better build quality
QQQ321
But all GS Series is same weight , right ? GS60 2PL looks nice
I need to pay about $3500 to get the highest level Aorus X3, a bit expensive for only
GTX 870M and I found some thread at USA that next gen NVIDIA graphic coming
now, how about Aorus with nex gen graphic ???
And, how about the distributor and service of Aorus ?
xXshad0wXx
yes all gs60 series is same weight. all gs70 series is same weight. all aorus x3+ is same weight. bro what are u saying? if you want the highest for msi gs60 is also 3.4k similar price to aorus... with 870m 3gb graphic card. aorus coms with 870m 6gb graphic card. plus a better cpu and cooling temperatures...
yes theres local distributor for aorus and will get local warranty if thats what ur asking.
