dappercivility
- Jan 22, 2019
Anyone has got the smart battery case? Any reviews or comments about this case? Does it really extend the life of the battery life significantly?
Thanks all for sharing. I got mine delivered yesterday. Noticed the smart battery cover constantly charges the iPhone. I am rather concerned that my iPhone battery will be damaged by the constant charging... I had misunderstood that the iPhone will be charged on and off depending on usage....
It is called a smart battery case for a reason. It will constantly charge your iPhone but it will not hurt your battery shelf life as iPhone will trickle charge from the smart case. So don't worry too much.
I have been using my iPhone 11 Pro Max with Apple Smart Cases for like 5 months and my battery percentage is still at 98%.
