Hi everyone, asking for a friend.
What would be a recommended build for running the ArcGIS Pro 2.6 system?
Can the recommended parts be obtained and built from pcthemes?
Budget wise, take it as a simple to mid range system is required at minimum.
All suggestions for every necessary parts and programmes will be greatly appreciated, e.g. Windows 10 Pro or Enterprise, etc...
We don't have much knowledge about office com builds so all advice are greatly welcomed.
Thanks in advance!
Sent from Samsung SM-N960F using GAGT
Thanks in advance!
