ARCTIS PRO WIRELESS ... good?
booest
https://steelseries.com/gaming-headsets/arctis-pro-wireless?color=black
buyimg-arctispro-wireless_black_001.jpg__1850x800_q100_crop-scale_optimize_subsampling-2.jpg
good? or waste time? or too costly?
EmPtYsOuLz
I've been using the Arctis 1 Wireless for work and gaming since the start of **
Less bell and whistles from the Pro but works flawlessly nonetheless. Mic and sound quality are both excellent.
The only few key things not included are the Bluetooth connectivity and swappable batteries
booest
the multi platform with mic is what draw me to this item
booest
appreciate the feedback:D
ItsmeagainhK
Not too bad. But the software is ... typically is connect once to sync and then delete the software. Super buggy I feel.
EmPtYsOuLz
On my work laptop I didn't have to install any software, it's just plug and play once you plug in the dongle
On my personal laptop I already had the steel series software installed so a bit more customisation options there
booest
understand.... but multi device will need to plug here and there.
which is why this artic pro is such a cool solution. everything in one. if it is just for 1 device i would just for the transmitter and receiver option in my room where i only have 1 device.. can even us my existing cans....
any apple to apple product alternatives?
booest
or is there a simple receiver for me to plug an exiting cans to?
All in one solution generally not as good and more expensive.
:s12:
Lots of wireless nowadays.
Maybe you want to consider HyperX Series as well.
https://www.hyperxgaming.com/us/headsets
