ARMAGGEDDON AQUILA-X MOUSE PROBLEM.
1taygu
Hi all,
Need all expert help to resolve the problem I am facing with this mouse.
After connecting it to the USB, it shows that installation fail and upon checking it shows as CODE 43 error in the device manager.
My laptop is currently using Win 7 Pro and my son laptop which is newly bought with WIN8.1 also faced the same problem.
Thanks in advance.
idjekyll
copied and paste from Windows forum for you.
Are you experiencing this only with USB mouse?
I would suggest you to follow these steps.
Step 1:
Open the Hardware and Devices troubleshooter by clicking the Start button, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Hardware and Sound, click Configure a device.* If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Step 2:
If that does not resolve the issue try the following steps and delete the Upper and the lower filters for the USB Drives and check.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article Back up the registry - Windows Help
To fix this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. To do this, follow these steps:
1. Click Start, click Run, type regedit, and then click OK.
2. Locate and then click the UpperFilters registry value. This value is located in the following registry subkey:
3. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96F-E325-11CE-BFC1-08002BE10318}
4. On the Edit menu, click Delete, and then click OK.
5. Locate and then click the LowerFilters registry value. This value is located in the following registry subkey:
6. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96F-E325-11CE-BFC1-08002BE10318}
7. On the Edit menu, click Delete, and then click OK.
8. Exit Registry Editor.
9. Restart the computer
