Ask a Bicycle Question - Part 5
Bakadead
guerclotti - road bike
Hi, I cant find much local review on this brand. Was wondering if anyone has a clue if they are good before committing into it?
Probably the eclipse series
I'mknotdumb!
Looking to get a foldable bike.
Requirements:
1. Folding mechanism easy to use
2. Wheels bigger than Vert's bikes
3. Not heavier than 12kg
4. Budget not more than $500
Any brands to recommend?
$500 slowly hunt in tgp :D i know a few guy manage to get bike that have good specs below $500
because there always be people that want to sell their bike ASAP because of family :(
Sadisticnoob
I ridden a guceortti record(i think) before. borrowed it from a guy
quite stiff and the geometry islike tt
but depends on the bike you buy
erwinrommel
i started from verge p9 and still using it, finally broke the 40km/h barrier going down slope using stock components :s13:
40kmh is impressive.. but normally people only look at flat road. :D
So far, I think only Tyrell foldies can hit that sort of speed.
30kmh on Tern/Dahon shouldn't be a problem.
VD
in before all time speed recorcd
40km/hr ain't gg to break any records :p
Been riding a Tyrell for about 1.5yrs and yes, it has fast pick up in speed, but it doesn't maintain a high speed over a long distance before yr legs gets jelly :p, cruising takes an effort unless you are drafting.
DigDub
ocbc cycle timing is out for those who went. go the website and scroll to the bottom and download the cert.
NoLogicLah
My timing
