Ask a Bicycle Question - Part 5
Xeon_sg
siao.. saw this post by someone on KH sale.
This is a ******* good deal la... Yeti not cheap.
shocking price.. fox factory series and a frame only $499.
Clearing old old stocks, that's why. 2009 models.
But still ride-able la. :s12:
patcheon
Just now, weather looks good, gone for a 10km ride with my old steel bike.
Cashflow202
I damn long never maintain my bike liao, got anywhere to service bike swee swee not
Sent from GAGT Android App
erwinrommel
Hi guys
I am riding a foldie and has just changed from 406 to 451 wheels. My current crankset is Ultegra 53/39 and I do find myself spinning out on flat roads at times.
Any 55T chainrings out there compatible with Ultegra crank? Or have to change to Dura Ace 566/44?
And my FD is SRAM Apex...
Thanks!
SmilingDevil
Tues night ride 8 pm at big splash. Selarang loop.
Paging for nologiclah and sadisticnoob(strong guy is back)
Sadisticnoob
Hi guys
Thanks!
you can use any chainring that matches the BCD of your crankset.
its 130mm for standard crankset .
you can take a look here
Bike24 - Chainrings of Rotor, Shimano, SRAM, Gebhardt, KCNC, FSA, Stronglight, Problem Solvers, O.Symetric, Specialized, B.O.R Germany, TA Specialites, Tune, Miche, Trivio, Campagnolo, Token, Surly and Pop Products
the outer chainring is ******* expensive, be prepared to put down at least 120 sgd just for the replacement.
if you want a custom sized chainring (>56)though i think FSA makes till 58T hard to find though. i think you might as well get it from fiberlyte
Fibre Lyte - Cycle Products - Chainrings
some points to note
most replacement replace all the chainring, chain and cassette at one go to even the wear between the parts
you might also need to lengthen your chain by a few links if you jump by a big number
your chainline wont be so good so certain gear ratio on your small chainring will be affected
HexenHeretic
depends on the rider too
i will agree with that, but i feel that a seasoned rider riding at single digit speeds(below 10km/hr) will still find it challenging to ride there on crowded weekend evenings.
key things to look out for:
1) toddlers and children
2) joggers with earphones
cyberet
I'm damn afraid of park users with headphones plugged in.
Anytime can change direction or stop.
even if jogging also can langar
