Ask a Bicycle Question - Part 5
WildBoarKing
Hello WBK, long time no see.
I am also looking to lose some weight from my mtb which i am now using for work commute. The rigid fork SASO and MOSSO, sg got distributor?
I think if i buy online and bring to LBS, not so nice.
And if my current wheel is running tserv 26*1.75 (previously running 2" knobby tyres), can change to 1.25?
Thanks!
Long time no see too :D
A fellow member just bought a SASO online, I myself have bought mosso from ebay too. Locally I'm not too sure.
its quite easy to install yourself, provided you have a pipe cutter, and have a way to install the starnut urself. And if the LBS don't carry this type of rigid fork or any rigid forks for the matter, they shouldn't mind.
and if your rims are not too wide, shouldn't have a problem fitting 1.25
WildBoarKing
for those looking to shed some weight off your mtb without spending too much, can consider the following
1) Rigid fork $90~$130
2) Slicks $90 ~ $100
3) Invest in a good seat post, like thomson. Second hand cost $70 ~ $90, and you would be surprised in the weight reduction
4) Cassette, do not use Deore, it bites into ur freehub body. XT cost about $50 ~ $80
3) Hollow tech cranks $130 ~ $200
Albedo
I don't have the stuffs u mentioned, so I got no choice.
Thanks!
furryballs
6) ride more train up legs $0 free!
WildBoarKing
Thanks!
I see. Then maybe u can pay the lbs to cut and knock in star nut. Then u install yourself.
Just find out how much u need to cut, that can be done easily by measuring ur old fork
Bear in mind most rigid fork tend to be shorter, so it will definitely change your geometry.
Sent from LGE NEXUS 5 using GAGT
Jay Bee
This guide is for those backside itchy feel like upgrading some stuff.
Plus... Sometimes it's really not logical to run knobbies of you know 90% of the time you are on road and don't have intentions in going to trails in the near future
actually imo road tires are better in trails :eek:
my original tyres (35psi) were those super big and fat types, cannot cycle in crusher run at all, it will keep digging itself in.....
now i ride with road tires(60psi), can easily bounce on sand and rocks....
the downside is road tires gets super dirty in mud and are very difficult to clean. much longer braking distance on sand. and almost no traction on wet grass :s22:
patcheon
My excuse for using knobbies on road rides ....To increase the effort needed with the same distance covered.:s22::s13::s13::s13:
Recently trying out a kick scooter to see if I can get the same amount of workout with shorter distance needed.=:p
Albedo
U mean the riding position will change? Like go lower?
Jay Bee
kick scooter not as fun as cycling :s13::s13:
rarenick
I rather ride with less effort to cover more distance to view scenery.
For kick scooter, becareful don't hurt your spine as was last time reported on news. And don't end up buying electric version. Lol
Sent from me to you using GAGT
ShinigamiX
can i juz ask wif a budget of like $250 maybe a bit more.... what kind of bicycle can i get?
Jay Bee
actually, effort wise, i think knobby or road is like about same leh..... road maybe 1~2kmh faster at high speed
positioning seems to improve power better :s22:
WildBoarKing
Thin tyres can off road, but all depend on individual. Look at the cyclo cross people..
But I believe generally trails riding in BT knobbies are more advisible
