asking for help, diy pc
zuppeur
I mainly use for stock/forex trading, surfing and watching movie online only. I need a pc that can support 2 monitors.pls recommend me a diy pc spec w/o monitor that can fullfil my requirement.it will be good to keep the price as budget as possible
thks
MoneyHoney
thks
hmm....the stock/forex trading uses any specific application?
ur diy spec can be very budget if this trading that u do is just via web browser. it can also cost alot of the application is very taxing or something.
i am not very sure about this trading thingy so cannot really help much
staedtler_07
Perhaps Just Java?
Normally it is done through a very fast internet connection speed.
TS might need a better graphics card for watching movies though?
Keen to know what kind of setup too.
zuppeur
For forex I using mt4. Not running any intensive application. I want a pc that can support 2 monitor so I can surf and/or watch movie using my second monitor.
nippp0n
CPU & Mobo: G2020 & Gigabyte B75M-D3V @ $160
Free 4GB Ram
ODD: Samsung DVD RW @ $22
HDD: Hitachi Deskstar 500GB @ ~$60
Case: ATX case @ $20
PSU: FSP 300W PNR @ $45
OS: Windows 7 Home 64bit OEM @ $110
Total: $417
Buy and build at Tradepac.
Some things to take note when dealing with Tradepac:
  • Be firm with your decision when buying from Tradepac. Don't be swayed by their sales assistant to upgrade and buy more expensive components which you don't require.
  • Check all the components you plan to purchase are correct before you make payment.
  • Stay at the shop and supervise them as they assemble your rig and make sure they return all spare chassis parts. You might want to take note that Tradepac cable management skills may not be up to your satisfactory level.
