Asus B85 Vanguard drivers problems, need advice
klap_hanz
I am using Asus B85 Vanguard now and i have installed all the drivers for this mobo but i am still getting an "Unknown Device" in Device Manager under System Devices.
Btw i am using Windows 7 Ultimate x64 as my OS and my PC is working fine now.
The Hardware Ids are ACPI\PNP0A0A and *PNP0A0A, i have googled and have tried donwloading and installing Asus Probe II and drivers but it is still shown as Unknown Device.
I oso can't install Intel Graphics driver on my PC too, it always prompt an error message saying that the minimum requirements are not met whenever i try to install the driver.
Can someone who is also using Asus B85 Vanguard mobo give me some advice and insights into the drivers for this mobo ? this thingy is really bothering me alot...
jtjt00
Try windows update to search for the driver? Right click on the unknown device in Device Manager and select search online for driver.
Reppps
if its working fine, don't bother.
if ain't broke don't fix it
xonix
It should be either Intel Management Engine or Asus Monitoring Device.
ah_khoo
there's an option to install all driver (from d dvd), have u tried that? :)
edited: try installin AI Suite III as well. just leave out those tools that u mite not need. :)
