Shyn85
- Jul 2, 2012
Those who installed this, did u consider heat-pump dryer?
I got both
issit mcst/ma dependent? or they cannot make you remove. scared of ngeow residents complain.
Any issues with yours so far ? Recently did the same as you.
Btw, you are not related to dark84 right ?![]()
which brand/place you buy from? can intro? HAHHAI have a automated laundry rack dryer with heat fan and heat pump dryer
The dryer with heat fan is useless, i use the heat pump dryer when the weather is humid.
I bought 太太乐 from TB.
cost me around 200+ 5 years ago, it's still working now. 4 pole, comes with UV, light and fan. didn't get the heat version.
now less than 200 can get liao.
5.0£FltWcErh6On《******************陶二宝****************** https://m.tb.cn/h.48Kvlu3?sm=e0f267【太太乐 电动晾衣架升降多功能阳台遥控智能自动吊顶伸缩晒衣杆机】
don't bother about warranty, the amount you pay can get 2.
Bro, do u have windows which u can close at ur balcony? If no, don't install as it won't work properly unless u just want a automated rack for hanging ur laundry.anyone know if can install at condo balcony ceiling?
Are u using it correctly? U have to install the rack with heater in an enclosed room, leaving only a small gap in the closed windows for the hot air to vent out.I have a automated laundry rack dryer with heat fan and heat pump dryer
Hi guys any handy man contact for installation??
Hi can you guys please recommend electrician, how much was charged?I bought an electric drying rack from xiaomi on taobao.
But I can’t find anyone to install for me.
Any recommendations guys?
please pm me if your electrician can do it
Hi, during my renovation, my electrician installed for me at a very low price of $50. But he was able to do it for so cheap because i gave him a lot of job in my place where the total electrician cost was upwards $4k.Hi can you guys please recommend electrician, how much was charged?
Does your aircon compressor get wet when it is raining? If yes, what is your concern of having some water dripping on it?are they reliable though? i have a small wet area behind but there's a window and if I extend the laundry system out, it'll drip all over my aircon as the ledge is right outside...?
maybe i've never used one before and was a little hesitant over price. yes currently using washer/dryer but there are occasional clothing - larger items or children clothes, which require handwashing and manual drying. through window makes sense for me at least when it comes to wind and sun. the way my lawn is structured, doesn't allow for sun or wind to enter. so yeah, have been pondering on the utility of investing in a system like this for years.Does your aircon compressor get wet when it is raining? If yes, what is your concern of having some water dripping on it?
Furthermore, do you mean you are not using a washing machine for laundry? Most of the time, the tumbling would result in no water dripping when you hang the clothes up for drying. Well, at least that is the case for the 3 washers I have used in the past.
Lastly, the system is meant for indoor drying, why are you extending it out through the window?
