Aztech DSL7002GRV-(s)
upgrade
Actually, there is more to just the rate. See the MCS Index Table at this link:
Modulation and Coding Scheme - MCS Index Table
You select 15: 130 Mbps or 270 Mbps. See the corresponding MCS Index 15 in the table. Too technical for me. At the moment I catch no ball.
Best set to Auto and let the router handle.
CarbonoAtom
Should I turn on stbc, does it increase my speed....
Btw, found singtel's new router DSL8800GR(S) from Aztech can view it on their website...... Any details about this????
mOomOo
have anyone have this problem.
add a port trigger entry. den try removing it...
my router page will just hang. i'm unable to access it till i restart it. and the entry will still not be removed.
CarbonoAtom
Best thing, call Singtel 1st then call Aztech if Singtel cannot, can u also help me ask when will the next firmware update be?
reVidia
Just got this router for my new fibre.
I am unable to find the mac address filtering feature
Under 5Ghz wireless setting, seems like there is no option to select channel width 20Mhz or 40Mhz
After enabling password for admin page, when I try to login with my password it says password wrong, had to reset the router. Not sure if its a bug
upgrade
Home Network Configuration > Manual devices reserve
The default for 5 Ghz is 20/40Mhz
The default for 2.4 is 20Mhz for neighbour friendliness.
I think you set the password for user, not admin.
CarbonoAtom
Software Version: V4.12L.08
Firmware is :293.6.1-008
Same as SaGu...
Does anyone know which website must we go if we want to update the firmware???? Singtel did not provide the link....
CarbonoAtom
Admin page is 192.168.1.254/singtel
Username: admin
Password : H3ll0t3ch
Then go to Home Network--> Wlan--> 5Ghz --> Advanced settings and change what you need to change....:)
ArrTeeOng
Hi all, I just got this router installed by singtel a few days ago. After we accidentally turned off the power socket that the router was running on, none of my wifi devices are able to connect to the router! what to do :(
edit: did a reset by holding on to the reset button, and all seems well now
upgrade
I believe the problem as described in my post of 10-Dec-2013. By default, the channels are set to auto. Check what channels all your wifi devices can use and set a fixed channel in the router accordingly.
The iDA Authorised Frequency Bands/Frequencies for Wireless LAN is 2.4000-2.4835 MHz. This translate to 2.4Ghz channel 1 to 13.
Page 16 of the iDA document:
http://www.ida.gov.sg/~/media/Files/PCDG/Licensees/SpectrumMgmt/FreqAllocAssign/RSMP.pdf
Based on the iDA document, the authorised channels for Singapore are:
2.4Ghz:- 1 to 13 (complete, no gap)
5Ghz:- 34 to 165 (complete, no gap)
This is the widest range possible anywhere in the world, reflecting iDA's good foresight.
I think routers and devices sold in Singapore should "ideally" work in these full authorised ranges. I stress "ideally" but we are not in a perfect ideal world.
1) Ideally for the routers, offer a wider spread to the layman users to avoid the congestion in the 5Ghz band that the 2.4Ghz is now suffering. I was surprised that the local RT-N56U only have 4 default channels in the 5Ghz band. Layman will be stuck.
2) Ideally for devices, to avoid the situation where they cannot connect to the router, especially when the router is set to auto-channel. I think we see a lot of this layman problem in the HWZ forum.
mOomOo
same as mine.
latest fw is .011 ...
maybe i get my friend's spare 7002 and try it out the new fw first.
Same as SaGu...
CarbonoAtom
Does anyone know the maximum usb storage that this router can handle???? On its samba server??? Also what does the new firmware do???? moom, updates please... Anything new??
