Aztech powerline socket help!!!
zephyr11
Hi there, I have the below connected.
1 x HL129EP
1 x HL115EP
They seem to be able to be paired. But there is no Internet activity light on, and I cannot get access thru the ethernet lan port.
Do they need to be same model to work? Or this should be OK? I got them separately.
Tried to reset them multiple times.
Could it be the singnet that is not working?
I am connected thru the WiFi, and the lan from the modem is working on the same singnet network.
Just the powerline lan doesn't seem to be working.
Need help!!!!
Thanks!
wwenze
You bought an Aztech product?
localITguy
Suspended
1 x HL129EP
1 x HL115EP
Need help!!!!
Thanks!
clearly your homeplugs are not paired correctly
Download the Asstak tool/install it and set a custom private network name
https://www.aztech.com/country/singapore/categories/aztech-datacom/homeplug/hl129ep
Under the Private Network Name
ftp://ftp.aztech.com/support/SINGAPORE/HomePlug/HL110EW User Manual v1.0.pdf
go to 29 that will tell u how to set a private network correctly.
never use the Quick/Connect /Pair button on the HomePlugs, they are not secure and others can tap into your network !
wwenze
Show us how you connected, and can you ping the router
zephyr11
some pictures of what i did,
IMG_1030 by chewyicecube, on Flickr
IMG_1031 by chewyicecube, on Flickr
not exactly sure how to ping the modem, but this is what i got.
C:\Windows\system32>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::91cd:ceb3:4c0c:d3f2%4
Autoconfiguration IPv4 Address. . : 169.254.211.242
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter isatap.{12BA80AB-C5FA-4D60-943F-E33D6BFDF9AF}:
localITguy
Suspended
refer my previous post
zephyr11
i pressed the simple connect on the main plug, hold for 10 sec, the lights all flashed. then go into the room to press the simple connect for 3 secs, then went back out to press the simple connect for 3 sec, the lights flashed, but couldn't connect.
tried several times.
localITguy
Suspended
READ again.
use the Tool to set the Network Name, do Not use the buttons
1. they are not secure
2. they don't always work
3. its not working because your block has other units unsing powerline also, and you might not be in the correct network. ( other unit's network)
localITguy
Suspended
aiya .
come i teach u
1. only connect Homeplug 1 to your PC ( Remove the Rest)
2. set the Network Name and hit Apply ( leave the box unchecked)
3. repeat step 1 and 2 for your 2nd HomePlug
hlots123
can he apply 1 at a time? eg apply network name to 1 homeplug 1st, then remove & bring the other homeplug here to apply same network name?
after both applied, then put back original location, test if connected?
localITguy
Suspended
that is a simple way, he does not even know how to apply the homeplug remotely correctly
this is more easy for him bah
