B4 Rig! help needed.
ahwei91
Superflower Golden Green HX is modular? I went to their website but they didn't indicate it is modular.
The distro has posted some pictures on the other site ......
Highlights
- 80PLUS Gold certified
- Dead Silent
- 105'C Industrial Grade Capacitors
- Patent 9 pin universal modular socket
- Flat modular cables
- 5 year warranty
- Low ripple/noise
- Tight voltage regulation
- Single Rail
- Maximum 12v with LLC-DC-DC design
- High 3A +5Vsb for systems that support off state charging
zjlim86
Highlights
- Dead Silent
- 5 year warranty
- Low ripple/noise
- Single Rail
So that is semi? am learning how to differentiate..
royfrosty
Yes asked my cousin to take it out. Its semi modular just like seasonic m12ii.
royfrosty
Ahhh. Will need to learn that. Then maybe get Tradepac to mount the cpu on the mobo socket.
If it's not modular then maybe stick to seasonic. R9 280x need until 620w ah? My current rig -> 520 w settle leh. Haha.
Just go 600w. Give more headroom.
Jian19
7970 jiak less power ~
mike911
http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/1_zps72ca1ba0.jpg[IMG]
[IMG]http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/2_zps54be96a7.jpg[IMG]
[IMG]http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/3_zps4093a71f.jpg[IMG]
[IMG]http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/4_zpsb8a0bb02.jpg[IMG]
[IMG]http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/5_zps8752853a.jpg[IMG]
[IMG]http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/6_zpsa42178ad.jpg[IMG]
[IMG]http://i1225.photobucket.com/albums/ee395/techdyanmic/Superflower%20HX/7_zps3ef7afeb.jpg[IMG]
Highlights
- Dead Silent
- 5 year warranty
- Low ripple/noise
- Single Rail
- High 3A +5Vsb for systems that support off state charging[/QUOTE]
[url=http://www.super-flower.com.tw/products_detail.php?class=2&sn=18&ID=109&lang=]Super Flower Computer Inc. - Computer case, Power supply[/url]
I always questioned myself why the physical set size differs from the product site image.
gaoxing84
Go to their website and order the 1600mhz... shld b $85 sgd total....
So cheap ah? Haha don't know r4 case can see the ram bling bling anot.
Btw if all red and black with red bling ram. Will it look good if I add a white led below to show the red theme? Haha or just get a normal red heatsink ram?
gaoxing84
Anyway, not sure if I shld wait for the non reference r9 290x first and compare the price difference? My brother maybe able to up his budget. Lol
How much can a 7750 fetch? 80 bucks? Lol.
Think shld try the superflower. Psu.
royfrosty
Superflower good brand. 7750 not sure. Maybe less than that lol.
Dont be like me think everything put red. That was my first idea. It will look bleeding.
So went on to put white led. Then can see nicely.
But went away with the corsair air silver color. Now red and white theme nicer to see.
shadow84
r4 and arc midi r2 case are the same.. So for me, the window is a little small. may not see the bling bling of the rams.. But if lean foward a bit, den can c..
Up to you whether you wan normal red heatsinks or led rams.... both about same price anyway...
For avexir rams, i believe the shipping to sg is US$10. Seems like avexir increase price le... Now 2x4gb 1600mhz is US$82. With shipping and conversion, it turns out to be S$119. So, maybe g.skills red rams more worth, if it is below $100.
gaoxing84
I check. The r4 windows quite big leh. Can see entire mobo. Haha so get the bling ram shld be fine. Haha
gaoxing84
That's what I thought. Too much red abit scary. So white to offset the red and can see nicely. Too bad the msi gaming gpu no backplate.
gaoxing84
R4 window, can see most of the mobo.
not sure if its the original window panel or modified.
shadow84
Then again, ur rig would be at your right, and would be in front of u.. so u cant really see much, unlesa u tilt it to face u, but ur ports would b facin away frm u....
royfrosty
Unless put on left side and tilt window towards you
