Backblaze Hard Drive Stats for 2017
ZrE0_Cha0s
Hard Drive Reliability Statistics for Q4 2017
At the end of Q4 2017 Backblaze was monitoring 91,305 hard drives used to store data. For our evaluation we remove from consideration those drives which were used for testing purposes and those drive models for which we did not have at least 45 drives (read why after the chart). This leaves us with 91,243 hard drives. The table below is for the period of Q4 2017.
2017 Hard Drive Failure Stats
Below are the lifetime hard drive failure statistics for the hard drive models that were operational at the end of Q4 2017. As with the quarterly results above, we have removed any non-production drives and any models that had fewer than 45 drives.
Read more: https://www.backblaze.com/blog/hard-drive-stats-for-2017/
Koenig168
Seagate did not do as bad as previously, if we only look at the stats for models with >1000 drives.
Pocoyoz
Wd red not good.
Why sg don't have hgst non nas model?
Sent from Pocoyo fan club using GAGT
setiardi
Take backblaze stats as a guide only. Their HDD is set in a dry, cold atmosphere in their DataCenter under almost perfect settings (clean voltage, minimal surges).
Our home PCs are subject to frequent daily power up/down cycle, sudden trips and may be subjected to poor ventilation.
So reliability may differ.
