Battery life decreasing so fast
roomer
yup.. same happened to me.
Check the battery usage see which app is the culprit.
I had one time encountered I airplane mode in cinema, came out drop 20%.
End up I check is YouTube app sucking 20%, not sure if it's a bug, but if you pause the video you are watching and press home, it will continue draining your battery very fast, so remember to close the app, or I think at least close the video you were watching and not leave it as "paused".
StanII
Battery drain is significantly worse on ios11 compared to ios10 unless my battery suddenly wear so much.
endlssorrow
Serious ah? Like that soon no diff from android processor liao
watzup_ken
does this looks normal?
almost a quarter battery gone.
I noticed your GPS is on. Do note that GPS drains battery big time. This is very obvious when you trying using Uber or Grab and it switches on the GPS, the battery will drop quite a lot while you stare at the screen watching where the car/cab is. In your case, you should find out what is switching the GPS on.
watzup_ken
Facebook and Messenger apps are the one should be turned off or turn off background app refresh. Those two are juice suckers.
I don't even install these. :s13:
You don't think you can really switch Facebook off. My understanding it is vey persistent in running in the background.
manofsorrows
Log out ! Thats what i do now. Only when i use, then i will log in.
Jirachi
Yeah. Those two apps sucks. Even if you turn it off it will still collect your information in the background or something. It’s like it’s still running.
And I don’t have Facebook anymore. Deleted the account and this do not have any of their apps.
