Battery not charging as per normal.
Magickiller9
Seems like there's an issue with my iPhone. Been charging for days. The battery level took 3 days to go from 60 plus to 99% and stuck there. Tried different charger and cable. Same result.
Any solution?
tec_geek
Any solution?
Try doing a hard restart? Press and hold the power button + home button until the  logo appears again?
lucified_lance
mine stuck at 89%
when i do hard reset, it took away 5% just like that.
switched from android to apple for the first time and had such a disappointment.
jq75
Any solution?
The battery level took 3 days to go from 60 plus to 99% and stuck there:eek:
which iphone?
try using original supplied charger and cable.
drain batt and charge and see how it goes
