BenQ XL2720Z noob help!
idjekyll
Hi Guys! anyone here using the BenQ XL2720Z or any model with similar settings? I just bought it and I'm having trouble downloading the driver. I usually don't have issues downloading drivers for other hardware but I can't seem to be able to use the disc or download from BenQ's site.
Also, why is the brightness drastically low when I turn on Blur Reduction? To put it simply, can current owners or someone in the know point me to the right direction to set up this monitor? Thanks!
htkm1
Hi there,
I'm using XL2420Z. You don't need to install monitor driver. Even if you do Windows will detect and you can install it under "recommend" on Windows up-date.
Next the CD has a manual. Go and read it! It tells you everything you need to know on how to set-up the monitor.
Than set your display to 144Hz. Default is at 60Hz.
On Color Calibration:
If you have bought a monitor calibrator. example: X-Rite, iDisplay Pro. Another brand is Spyder.
Use it to calibrate the monitor. For me I selected "Standard" in Picture Mode and calibrate the monitor.
If you Do Not have a monitor calibrator, Not to worry. Go and D/L(Down Load) BenQ Display Pilot software. Link below.
Downloads | BenQ Gaming Monitor
Use it to calibrate the monitor. It won't be as good but it's better than not calibrating at all.
Save this setting in S Switch. From 1-3 which one you choose to save is up to you.
The Display Pilot software can do other stuff like setting Picture Modes on the 1-3, S Switch without going into the menu
I use this calibrated setting to play D3 or normal usage when I want the colors to be rich. But the quality cannot compare to an IPS panel.
For BF4 Or other FPS(First Person Shooting) games:
This is how I set-up.
Select FPS1 in Picture Mode.
Below settings are under Picture Menu.
Black eQualizer set to 20(max). You can try 10 first. What does this do? You can see enemies hiding in dark areas.
Blur Reduction "Off". You might want to turn it on if your playing racing games???
AMA set to "Premium". Default is High. This improves gray level response time.
Instant Mode, set to "ON". This reduce input lag.
Try this setting. From there you can custom to your own.
cheers- htkm1
idjekyll
Hi there,
cheers- htkm1
awesome! and yep i just downloaded the display pilot software but yet to tinker with it. thanks for your tips! will be using them when i get home today. :)
htkm1
You can install the driver that came in the CD. But as I have mention. Windows will detect it and recommend a new driver in Windows up-date.
You will need firmware Ver.2 if your going to use Blur Buster Strobe Utility with BenQ Blur Reduction. See link below.
Blur Busters Strobe Utility for BENQ Blur Reduction | Blur Busters
It's to make BenQ's Blur Reduction brighter and clearer/sharping looking motion.
IMO this is less important compare to the Black eQualizer which helps see in dark areas. Also when you "on" the Blur Reduction not only it become dark but the flicker-free is turned off as well.
cheers- htkm1
hmm everything that came up in Google searches indicated i need to download drivers. if no need then ok then. How bout this whole v2 firmware thing?
idjekyll
cheers- htkm1
so basically if you're not playing any racing games or anything that involves quick movements then its better to off Blur Reduction?
htkm1
From what I read on BenQ web site it's to reduce eye fatigue. But yeah my conclusion is say same as you. Don't play racing games don't on lor.:D
Honestly, playing FPS like BF4 where got time to stop and see if there is a difference in clarity/sharpness. You stop to see.... the other side shoot, you die liao.:D
idjekyll
actually i dont mind switching it on as i think you can see a smoother display overall but the drastic reduction (even at full 100 brightness) bothers me. and i cant be assed to do the v2 firmware thing. have you done it? any idea how?
Trans-Am
Hi there,
cheers- htkm1
Nice:s12::s12:
htkm1
Same here. I also cannot take the light reduction so I turn it "off". I'm getting 160-190fps and max. 200fps. See screen shot below. :D
[/URL][/IMG]
Again same here. I haven't tried it. You can down load the utility and try. If your monitor is already with firmware ver.2 it will run. if not it will say no compatible or need firmware up-date.
Takechan
I was hoping you'd forget to leave your squad so that we can see your IGN :s13:
htkm1
Tried the Strobe Utility. Sinced it worked. That means the monitor that I bought in PC Show has firmware ver2 installed liao.
idjekyll, not much diff. The brightness can only up a bit. Still looks dim.
[/URL][/IMG]
shadow84
[/URL][/IMG]
What settings are u playing in???? 200fps on BF4 leh...
