Best Mid Tower ATX case?
zeroangel
Would like to take advantage of upcoming 11.11 sales, question as above.
I currently am using a Tecware Edge, but the PSU compartment is so isolated and narrow that I have to bend my cables crazily to connect everything, that ain't good for the cables right?
gld998
Mid Tower mostly like that one. Budget? Go for full tower? Consperm have alot of space if full tower.
gld998
Err which one? Lol. Budget maybe around $100 max
100 budget? its either upgrade your psu to modular one then only use the cables u need or get mid tower without the psu shroud. I got the tecware alpha, so I know what u mean.
Super Flower Leadex Silver 650W should be semi modular rite? Just remove the unused power cables.
Solo_Apple
Buy the Primo P37 from Taobao or JD and ships it here.
Cost shall be ard $100-120 depends on your discount.
zeroangel
All the cables are already in used, that's why its plugged in. Its just the way the case is structured.. My PSU is a full modular btw hahah
Psycovirus
$100, go Phanteks P300. It's about $99 retail. Found one for $95. Built in one, very awesome to work with.
Also, you will need to purchase 2 more fans for the front. Suggest 2x 140mm ones.
Bardiel
no consider the sharkoon tg5?
i did a few build with it, nice n easy cable management. alot of option for fan mount
Hashketh
Phanteks P400 for its execllent value, immaculate looks with one side tempered glass panel. I'm going for the glacier white myself
