Bluetooth and WiFi adapter
queerquirks
Using lan for my pc but some mobile apps utilise Bluetooth or WiFi for use on pc.
Saw Intel Ax200 but its m2 slot which taken by my Ssd. Don't think got another m2 in my mobo. Can get m2 pcie adapter but wanna hear other suggestions first.
Any to recommend?
shadow84
The intel ax200 m.2 should be different from your ssd m.2 slot. But in any case, getting with pcie adaptor shld be easier. Im using a set bought from from taobao. Comes in built with bluetooth, just need to connect to USB 2.0 port.
CursedHamster
Should just get the PCIe adapter form if you have free PCIe slot not being used. I would also highly recommend you to get those with the movable antenna base so the signal won't get easily degraded by your metal case.
Goodshot
I just bought a pci USB 3.0x 4 slot only $11. Just plug in can use already. Don't even need driver
