Bluetooth Problem
Phen8210
Last time i can connect bluetooth speaker and ds4 controller at the same time, now when i connect my ds4 controller, the bluetooth speaker will disconnect. Reset both device reinstall driver still same why ah.
hafiz116
Is this in built bluetooth on the motherboard? I had a lot of issues with this a while back and it turns out to be driver issues. I did get the latest from the manufacturers website, in my case it is Gigabyte but the problem persisted.
Also, if your motherboard comes with an antenna the bluetooth signal is amplified via that so make sure its connected even if you're not using WiFi. When I installed mine this did not help the situation at all and I was still having very choppy bluetooth audio even at distances of 1-3 feet.
Eventually someone recommended me to go dig for the manufacturer of the bluetooth itself and get the driver from there - THAT SORTED IT FOR ME!
Phen8210
no i using intel wifi card with drivers from intel page
:s13:
Can be your bluetooth device or driver,
Can your DS4 controller,
Can be your bluetooth speakers.
Most simple solution is buy a cheap $10 USB Bluetooth Dongle.
https://shopee.sg/UGREEN-Original-W...io-Receiver-Transmitter-i.64922680.1148147460
Sic you $9 Ugreen USB Bluetooth Dongle.
RyoHarusaki
I use Bluetooth usb dongle for my xbox controller on pc.
Cheap and fuss free
Win10 auto install driver
