Bluetooth / Wireless Speaker Recommendation
CrispyPeddler
hello all, im lookin for any bluetooh / wireless recommendation for speaker to reduce my table clutter.
not really an audiophile, just need something that works and is good enough. budget preferably below S$100.
i googled some and alot recommending creative pebble? a soundbar with just usb cable to charge would be cool too
TIA!
Koenig168
You can take a look on Creative's site. There is a sale going on.
30% additional discount "TEN30" on top of the sale price which applies to the earlier versions of Pebble but not V3.
Deceased
Pebble will still need to be powered by wire even if it’s paired via Bluetooth though.
Dr.Vijay
Administrator
Administrator
I would recommend the non-air version of Creative Stage if you can -- much better audio.
That is, if you can stomach a slim sub under your desk and having it wired all the time.
Here's our say about the Stage Air V2, which kind of feels like an undecided product and trying to appeal to a wide range of folks, but it's not the most effective cost-wise (compared to the Pebble V3 for example):-
https://www.hardwarezone.com.sg/review-creative-stage-air-v2-review-singapore-price-specs
tigerwoods
I have both Creative peeble & Creative Stage
The peeble sounds better, has better bass, better sound seperation and has wider sound stage when you put beside your monitor.
The Creative Stage is just too short making the sound stage too narrow with bad sound seperation, all sound is coming from the center of your monitor.
hdtvsg
Go for UE Wonderboom 2 or 3. It doesn't take up much space or you can hang it anywhere and also can bring it with you when you are travelling. Lastly, it sounds really really good.
CrispyPeddler
Reviving the thread. Looking for any latest wireless speaker with minimal cable. Maybe just usbc charging
86technie
The new Creative Stage SE under $100.
CrispyPeddler
How about Earfun Uboom L / soundcore 300? There is a list on Reddit highly recommend this 2
