Browsers problem on MacAir
sfugel
All my browsers,safari,chrome,Firefox,etc crashed when open. Only can open in safe mode without crashing. Scoured the net for solution,so far nothing helped. Can anyone offer a solution or have face this problem? Thanks.
chehjin
what was the last thing you did before this happened?
the only thing I can think of right off my head which can affect all browser is a 3rd party plug in added to all of them.
PetPet
Moderator
Moderator
Safari > Menu > Preference.
Click on Extensions tab.
uninstall the plugin that you last install.
leinad
Which web site are you browsing on all that crashed it?
Alternatively, send it in and see. Either it's something you installed, it's the web site that you are viewing, or the RAM might be problematic.
/Dan
havetobuy
me present mac15pro sufferred the same problemo
i had to switch to camino(yes ole browser) it worked
all the present chrome/firefox/torch crashed
the main culprit is the gfx gpu on board overheated..
2nd option placed those cheap fan underneath the macbook( mine modified last much much longer)
now so fedup sent for 2ndhand gpu replacement (havn't know the outcom yet)
chehjin
Tried that,no plug-in visible.
now try, go to
<Mac HD>/Library/Internet Plugins
inside should have stuff like flash plugins etc...
copy all out into another directory and start up the browsers...if it works..1 of the plugins is giving you the issue.
eliminate or just start afresh as you wish
sfugel
now try, go to
Tried,still problem still persist. Headache!
sfugel
run disk utility, repair permissions and check HDD status?
I did that,nothing seems to be amiss,except "Safari should be drwxr,-xbut that are rwxr-x....." .....not savvy enough to comprehend that though.
chehjin
that could be the reason, maybe copy that line and check in google.
sfugel
Thanks for all your time and help Bro chehjin.Appreciate it. Cheers.
sfugel
Nope Bro,still unable to resolve issue,will send it in when I have the time.Anyhow,I really appreciate your time to try to help me with it.
