BSOD. Help needed (hardware issue)
Starrry_
hi all. Im getting 0x1e error. was told it was hardware.
i went to RMA my PSU turns out it was faulty. Used a new RAM also same problem. BSOD happens every 3-30min. after start up AFK also BSOD.
event view says:
The Intel(R) HD Graphics Control Panel Service service terminated with the following error:
%%-2147467259
The following boot-start or system-start driver(s) failed to load:
cdrom.
this 2 errors only. Can any one help?
grimfan
This could be a hardware or driver (software) related issue.
Assuming there are no more hardware related issues, try to do a complete uninstall (plus deletion) of all graphic related drivers on your PC; Intel plus nVidia or AMD drivers if you have either.
Restart to Windows and see if there is still BSOD while running on generic drivers that Windows will use when no specific drivers are found.
If still no BSOD, proceed to reinstall the latest stable version starting with the primary graphics drivers you are currently using for your display. If that is stable then you may want to install the other graphic drivers.
Starrry_
Thanks for your solution. But if i install all graphic related drivers i have to connect my display to the mobo? or can i leave it on my GPU. I also cant seem to locate my intel HD driver to update/uninstall
hlots123
Starrry_
where can i get the dump files? Cant seem to locate %SystemRoot%\MEMORY.DMP
commach
%SystemRoot%\MEMORY.DMP = Windows\memory.dmp
You are using the default setting for system dump which is a single memory.dmp.
Change the setting to small memory dump instead of full memory.dmp (default). Full memory dump does not necessary meant you get much more useful information to debug in the event of system crash. In most cases, small memory dump contains enough information to debug the crash.
Refer to this on how to access the setting for small memory dump.
Starrry_
my memory.dmp seems to be missing. I downloaded NirSoft BlueScreenView...
it sees the C drive minidump folder.
Some dmp contained some other errors. But all had this ntoskrnl.exe
090315-8720-01.dmp 03-Sep-15 10:30:22 AM KMODE_EXCEPTION_NOT_HANDLED 0x0000001e 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 ntoskrnl.exe ntoskrnl.exe+73590 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.18933 (win7sp1_gdr.150715-0600) x64 ntoskrnl.exe+73590 C:\Windows\Minidump\090315-8720-01.dmp 4 15 7601 352,392 03-Sep-15 10:30:54 AM
deepblue_82
what have u been using all along?
on board or gfx?
what what i see its the onboard issue.
u can find the drivers from ur mb cd...
disable your onboard and uninstall..
then change to your gfx..
Starrry_
always been using dedicated..gtx 780...I cant seem to find the mobo one to uninstall.
uninstall the intel HD one or disable GPU uninstall and reinstall GPU?
grimfan
What are the results of your troubleshooting? Still having BSODs?
As suggested, it is good to look at the dump files to understand what is happening but generally the troubleshooting steps are the same for driver related issues; install latest stable drivers.
It's your decision which GPU you want to run after you install the GPU drivers but I suspect you would want to use the more powerful graphics adapter (your nVidia card), so connect to your GPU bah.
If you can't find the uninstaller for the Intel drivers in "Control Panel -> Programs and Features", goto Device Manager and uninstall the drivers for the Intel GPU under "Display Adapter" and delete the drivers files when prompted.
commach
Perform a memory test to determine the health status of the ram module.
The driver/process in the stack are pointing to multiple possibilities, the pool of the fault is simply too large, not typical software issues.
Starrry_
please upload the dump file ,not so us screenshots of it
Thanks guys! seems like problem is solved. Reinstalled all graphic and mobo drivers. Working fine now. 12hrs since last bsod. :)
Starrry_
looks like problem is back. here is my dump file
http://www.filedropper.com/090415-6084-01
here is the dump
grimfan
here is the dump
List your PC specifications, the OS you are running and the drivers you are using.
Still seem to be a driver issue; did you download the latest drivers from the respective websites or using some other drivers?
Starrry_
OS: Win7 pro 64bit
intel i5 4670k
pus crosair rm 650
gpu evga gtx 780
mobo msi z87-g45
ram avexir core ddr3 8gb x 2
hdd samsung ssd pro + WD cavier black
i have completely reinstalled my GPU. uninstalled my 780 driver, it became VGA default, then shut down and plugged into my mobo (intel hd 4600) then uninstalled that one too, and became VGA default too.
Plugged back into gpu with vga driver. Then reinstalled my 780 driver. rest has not be reinstalled.
i used MSI software to update all msi driver...
commach
My advice will still be the same, perform a memory test.
I won't even bother to debug the dump before a memory test, a typical hardware issue rather then outdated driver.
