BSOD. help please.
alextheong
last night i was using my computer then suddenly the display went out. the computer is still running but my monitor cannot detect.
i restart the computer and i get this.
what died? what can i do?
GrimaH
Your card's probably dead.
If it's still got warranty, get it to the distro.
edit: Try plugging in to the motherboard's output instead of the card's, to confirm whether it works.
LesterQ
If the p8p67 is your mobo... Then you are down on luck.
https://www.asus.com/Motherboards/P8P67/#specifications
Dont have any display output right?
1 x PS/2 keyboard (purple)
1 x PS/2 mouse (green)
1 x Bluetooth module(s)
1 x eSATA 3Gb/s
1 x Power eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Coaxial S/PDIF out
1 x Optical S/PDIF out
6 x Audio jack(s)
Maybe try the OLD blow the connections trick and pray. Haha
alextheong
for awhile now i kept seeing that the device driver was crashing while i was gaming.
has it really reached the end of its life? bought it in 2010
or is it my usage? there isn't anything i run that pushes it to its peak performance, or at least i don't think so.
addthewin
graphic card bro.. this is call display garbage.. most likely beyond repair.. just send for RMA usually 1 to 1 exchange..
