waterbright
- Apr 20, 2018
Unbinding
We have encountered the term unbinding (nibbāna) many times as the name for the goal the bodhisatta sought in the course of his quest for awakening. When a path of practice did not lead to unbinding, that was grounds for rejecting it. When it did, that was grounds for accepting it as right and true. The term itself seems to have been a common one for the spiritual goal sought by a wide variety of seekers in his time. Literally, it meant the extinguishing of a fire, but what did an extinguished fire represent to the Indians of the Buddha’s day? Anything but annihilation.According to the ancient brahmans, when a fire was extinguished it went into a state of latency. Rather than ceasing to exist, it became dormant and in that state—unbound from any particular fuel—it became diffused throughout the cosmos. When the Buddha used the image to explain the goal of his practice to the brahmans of his day, he bypassed the question of whether an extinguished fire continues to exist or not, and focused instead on the impossibility of defining a fire that doesn’t burn: thus his statement that the person who has gone totally “out” can’t be described as existing, not existing, both, or neither.
When teaching his own disciples, however, the Buddha used unbinding more as an image of freedom. A common Indian belief at the time saw burning fire as agitated, dependent, and trapped, both clinging and being stuck to its fuel as it burned. To ignite a fire, one had to “seize” it. When fire went out, it let go of its fuel and so was “freed,” released from its agitation, dependence, and entrapment—calm and unconfined. In this way, the Buddha used the term unbinding to indicate the freedom that comes when letting go of the clinging that constitutes suffering.
Knowledge of unbinding came to the Buddha as a result of developing right view, but is separate from right view because right view—like all the other factors of the path—is fabricated, whereas unbinding is not. Not only does unbinding lie beyond right view; it lies beyond space and time altogether. Although a person totally unbound cannot be described—given that people are defined by their clingings and cravings, whereas a person unbound has gone beyond clinging and craving—the Buddha stated clearly that unbinding does exist, and that it is permanent and unchanging. In fact, he gave it many names and illustrated it with many similes to show that it was the highest, most desirable goal possible. These names and similes fall into five groups, conveying five important facets that anyone curious as to whether it’s a worthwhile goal should know.
The first is that it’s not a blank of nothingness. Instead, it’s a type of consciousness. But unlike ordinary consciousness—as included in the aggregates or in dependent co-arising—it’s not known through the six senses, and it doesn’t engage in fabricating any experience at all, unlike, for example, the non-dual consciousness found in formless levels of concentration. The Buddha described this consciousness as “without surface” and “unestablished.” His image for it is a beam of light that lands nowhere. Although bright in and of itself, it doesn’t engage in anything, and so can’t be detected by anyone else. Because this consciousness is totally unrelated to the six senses (MN 49), it will not end when the arahant’s six senses grow cold at death (Iti 44).
The second facet of this dimension is bliss: unadulterated, harmless, and safe. An important aspect of this bliss is that it is peaceful, entirely conflict-free.
The third facet is truth: Because it’s outside of time, it doesn’t change, doesn’t deceive, doesn’t turn into something different. And because the bliss of unbinding is permanent, unchanging, and true, it puts an end to all desires for further-becoming.
The fourth facet is freedom: from hunger, from suffering, from location, from restrictions of any kind.
The fifth facet is excellence, higher than anything known in even the highest heavens. In the Buddha’s own words, it’s amazing, astounding, ultimate, beyond.
“There is that dimension, monks, where there is neither earth, nor water, nor fire, nor wind; neither dimension of the infinitude of space, nor dimension of the infinitude of consciousness, nor dimension of nothingness, nor dimension of neither perception nor non-perception; neither this world, nor the next world, nor sun, nor moon. And there, I say, there is neither coming, nor going, nor staying; neither passing away nor arising: unestablished,36 unevolving, without support [mental object]. This, just this, is the end of stress.” — Ud 8:1
