kurt111494
- Feb 4, 2008
Hi guys,
I'm deciding on a CPU case as I'm building my custom rig.
The PC specs I'm looking at aren't super high tier type, so I just need a budget casing. However, I need one with very good cooling and ventilation capabilities because my room is really stuffy and humid.
I also wanna avoid any kind of LED lights the casing emits (be it from the fans or whatever).
Right now I've narrowed down to the CM N200 or the Deepcool Smarter. Which one is better at cooling? I'm open to suggestions for other cheap/budget casings/chassis as well
Thanks!!!
Thanks!!!
