Build advice - 2500 budget max
sp0inK
i7 9700k
z390 mobo (no need ac wifi, any recommendation?)
cryorig h7 quad lumi
2x8gb corsair vengeance 3000mhz
seasonic focus plus 650w gold (pref 10yr warranty)
1tb 970 evo nvme
zotac 2070 super extreme amp
nzxt h510 elite
no need monitor, windows etc
i7 9700k
1tb 970 evo nvme
nzxt h510 elite
this specs need 2.5k meh???
SkyShroud
What the computer use for?
Gaming? You want optimal gaming experience?
SEvsNK
i7 9700k
1tb 970 evo nvme
nzxt h510 elite
Z390 can consider aorus pro
arfness
i7 9700k
1tb 970 evo nvme
nzxt h510 elite
Ya good build but u can change a few things to get better value and also depending on the shop
i9700KF (only diff this does not include discrete gfx), also shop dependent but can find for maybe $30-$50 cheaper.
Z390 aurous elite is a good board. Just avoid MSI Z390 pro carbon at all costs. Very bad cooling.
1tb 970 evo nvme - Expennnnsive, Adata SX8200 Pro is almost half price
Seasonic FP 650gold (7 years) - save $30-$50 really need 10yr?
With that you can bump your card to a 2080 or 2080 Super if its a good price (cause the price/performance is not great on the 2080 super). Can find some 2080 for $900-$1k on lazada, i see most shops in simlim dont carry them anymore.
Again very shop dependent and most shops can give a good $100-$300 discount if you buy entire PC from them.
MrAwesomeX
NVME dun bother with samsung tbh , their current value price performance is no good at all. TLC Adata or corsair good enough , dirt cheap during sales too:s12:.
I would not buy a intel chipset cause very difficult to upgrade in the future plus nowdays amd price performance is too superior:D.
