[Build Log] Ebony and Ivory
gaoxing84
your temps good. i think need to check my cpu settings tonight. not sure if i screw it up that time.
but my fan spin at 75% only when on 100% load and 25% on idle. haha quiet.
tonight go check again
monikernemo
Yeah just zham the settings Haha then also set voltage to 'Adaptive', multiplier to 'dynamic'
Sometimes idle at 0.800v. Got people manage to enable C7 power savings then can get to 0V vcore on idle on ASUS boards. MSI boards apparently cannot enable C7 power savings hmm then I searched up, they say C6 and C7 actually almost same thing.
You using Corsair SP Fans? How are the acoustics? I have 5 noctua ippcs 3krpm. At max speed, fans are loud as fug.
I use a pwm fan Splitter so control everything from one source. I just use bios to control. Temp at 40-50°c, speed at 25-32.5%. At 60° and above I raise it to 62.5%. Very weird MSI deploys 12.5% per level.
Anyway I figured that even at max fan speed, max thermals won't make much difference :)
Sent from JARVIS using GAGT
monikernemo
One last photo? Hahaha
gaoxing84
i forget to on C-Step and C1E . haha i think that changed when my bios reset all the settings.
now on idle less than 40.
31-39 degrees
onload less than 70degrees
yeap. all corsair fans. performance. i never blast full. i got 5 corsair SP120 Performance, 1 corsair af120 performance and 2 AF140L.
I all connect to 4pin cpu header with splitter. so on idle, i run them at 25%. ramps up to 75% when on full load.
no need 100% ba. damn kb.
right now i can relax and chill, knowing my cpu can last me another 1-2 years before upgrading.
as for my gtx970, i never even bother to OC much. just add abit here and there but run stock most of the time.
idle 36 degrees
on load i think never hit 55? forget already.
your temps idle under 30, you inside aircon room?
